problem starting xr3i efi convertable
Old Aug 3, 2009 | 06:04 PM
sideways sie's Avatar
sideways sie
Default problem starting xr3i efi convertable
Hi lads n lasses i have problems wit the other halfs cab it will start eventually but takes about 10 mins of cranking and is worse when the engine is cold ie in a morning the fuel pump is priming ect and i have a good strong spark any ideas would be appriciated cheers
Old Jul 20, 2010 | 09:13 PM
nadagila's Avatar
nadagila
Default same problem
did you cure this problem cause its doing my head in now
Old Mar 11, 2018 | 09:06 PM
EVOXR3ICABBY's Avatar
EVOXR3ICABBY
I had the same problem with mine a couple of years ago and it was a relay fault.Been ok since.
Kyle Langford
27
Aug 5, 2019 07:54 PM
EoinXR3
Sep 7, 2015 05:44 AM
Dahl88
Aug 22, 2015 08:16 PM
marky_g
Aug 15, 2015 10:43 AM
Bloody-Fox
Aug 3, 2015 07:48 PM
