1.8 0 st170 conversion help needed
Old Aug 2, 2009 | 01:38 PM
Phipsy's Avatar
Phipsy
Default 1.8 0 st170 conversion help needed
I have a 1.8 focus with a st170 engine fitted, It is still currently running on the 1.8 loom and ecu, After looking at both looms i have noticed there is one plug different which goes to the under bonnet fuse box, The 1.8 has 2 wires and the st loom has 3 wires, Will i need to change the fuse box to overcome this problem?
Also if i do change the fuse box will i find myself having to change something else along with it?
I have also been told i can use a shift light to control the VVT, Does anyone know if this is 100% possible and safe?
Any help is much appreciated.
Porplus12
Sep 10, 2015 07:20 PM
Palethorpe01
15
Aug 18, 2015 06:09 AM
coozer
Ford Focus Range
Aug 15, 2015 10:26 PM
track.focus'd
Aug 12, 2015 05:53 PM
col93saphcos
Aug 7, 2015 03:21 PM
