Injectors have no power Help please
Old Jul 29, 2009 | 05:48 PM
alo's Avatar
alo
Default Injectors have no power Help please
I've got a problem with my cosworth I'm not getting enough power to my injectors. The plugs are reading 0.1v whilst cranking. The injector relay clicks on ignition,so it has power. fuel pump primes.etc
I'm running a 2wd engine loom and a L6 ecu with a chip
Old Jul 29, 2009 | 07:36 PM
costina's Avatar
costina
Live long and prosper!!
bad earth on intake manifold
Old Jul 29, 2009 | 07:48 PM
alo's Avatar
alo
Cheers for getting back, ive checked continuity between the earths on the loom and chassis thats fine. Is there any other checks i can do? could the earths still be bad? cheers, really can't get my head round this one
Old Jul 29, 2009 | 08:57 PM
costina's Avatar
costina
try
www.bigturbo.co.uk for the wiring diagrams it may help a little
I'd change the relay and fuse and check voltage at the ecu
Paul
Old Jul 31, 2009 | 12:20 PM
alo's Avatar
alo
Relay and fuse fine, ecu has voltage. It's very strange i can't work it out.
Old Jul 31, 2009 | 09:31 PM
costina's Avatar
costina
so its a non starter ?
if so you need to check Phase sensor and TDC sensor
Paul
Old Aug 1, 2009 | 02:52 PM
This is not an earth problem, at the injectors when ignition is on you should have on 1 terminal(each injector) 12V LIVE, permanently, the earth at each is pulsed as needed by ecu, so see if they are getting pulsed or it it's the 12v dissapeared, if so temporarily reinstate it then try.
Old Oct 3, 2009 | 10:31 AM
hughy's Avatar
hughy
hi mate, did you have any luck since this is the same problem im having? cheers hugh
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mk3ste
Oct 17, 2021 10:09 AM
Mark_
14
Jan 16, 2016 05:27 PM
Nov 1, 2015 06:53 PM
Iain Mac
Sep 30, 2015 09:39 PM
