revs issue when changing up the box
Old Jul 29, 2009 | 06:55 AM
a96droptop's Avatar
a96droptop
Default revs issue when changing up the box
The problem I have is that when driving and I change up a gear the revs increase a little as if ive still got my foot on the gas, it don’t do it changing down the box only up, its been doin this on n off now for a couple of weeks and I wondered if anyone has any ideas as what could be the cause, oh and it’s a 96 18 zetec 118kw
Any help would be appreciated
Old Jul 31, 2009 | 11:26 AM
keyz's Avatar
keyz
Arse
youll probs find its the idle control valve, Which is situated at the back of the engine ( inlet side ) between the plastic manifold. Secured by 2 x 8 mm bolts and a clip on cable on the right .
once off ( can be tricky ) clean with carb cleaner, and let soak with fresh carbcleaner & wd40 for about an hour. ( i did mine with wd40 and petrol )
Leave to dry or aid in drying with air line etc and then refit. ( I also d/c teh battery whilst doing this for my own reassurance , buts its upto u )
Revs should now be fine, and idles alot more smoothly, Or another possibilty is that u have an air leak Or your Exhaust sensor ( on ur down pipe ) has gone.
simple way - cold engine = MAF air intake / idle control valve
Hot engine = Exhaust emmision sensor
Old Jul 31, 2009 | 03:26 PM
a96droptop's Avatar
a96droptop
thanx fella i will give me icv a clean and see how it goes
Old Aug 12, 2009 | 09:39 AM
binners's Avatar
binners
Default 1.6i cvh EFI Engine
Can ayone tell me where to find the idle control valve on a 1.6 CVH EFI engine 1991 build?
Any help much appreciated.
Thank you
Alan
cameron2
Aug 25, 2015 07:18 AM
Anutternutter
Aug 21, 2015 06:07 PM
JoeyBoyden
Aug 18, 2015 05:56 PM
ekjim
Aug 17, 2015 08:57 PM
CabrioTurbo
Aug 1, 2015 11:04 AM
