Zetec conversion help..
Old Jul 28, 2009 | 08:54 AM
xtrmjks's Avatar
xtrmjks
Default Zetec conversion help..
What do I need to connect on 1.8 loom to make it run...?
Any one done Zetec in MK6 van?
Old Jul 28, 2009 | 04:57 PM
xrmalin's Avatar
xrmalin
If you want to put the engine in a mk6 van i would just buy a cheap mot faliure car fitted with the engine you want then just swop everything over from car to van
mark.
Old Jul 28, 2009 | 05:14 PM
xtrmjks's Avatar
xtrmjks
mark.
I've got whole mk6, with 1.8...
just wondered if I have to swap whole loom (inc. interior)?
or just wire up zetec loom to diesel??
Old Jul 28, 2009 | 05:18 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
you will be able to cut the zetecs loom back to just the engine harness the wire that into the vans loom no problem dont for get about the tanks tho as you will need it for the efi
Old Jul 28, 2009 | 05:20 PM
xtrmjks's Avatar
xtrmjks
Any details on loom mod?
Can I use diesel tank with inline pump?
Old Jul 28, 2009 | 05:23 PM
clarke5700's Avatar
clarke5700
lol its not a mod its just cutting back the standard loom and splicing it into the van loom. i cant see why not. im not sure if the van tank will have a swirl pot tho. also what inline pump?
Old Jul 28, 2009 | 05:31 PM
xtrmjks's Avatar
xtrmjks
I can't find details (ecu pin outs etc.) on zetec or diesel wiring..
inline, like cosworth.
Old Jul 29, 2009 | 07:59 PM
Dr Knockers's Avatar
Dr Knockers
i've been searching for a while for the pinouts on a 1.8gti zetec ecu(slug) and no joy, all i have found is the 2.0 pinouts which dont match, as its say 22 should be fuel pump relay but there is no pinout wire loom side.
This helped as it kinda the reverse and indicated that fuel pump relay on a 1.8 ecu is pin 53 to me....
http://www.ford-force.com/forums/ind...showtopic=7589.....
the closest i could find is this
https://passionford.com/forum/ford-f...rge-valve.html
buts its for a focus i think
It got me running today with my conversion on a mk4 escort estate with a 1.8 zetec lump, crazy thing was engine would not shut off on key. Tried pull of positive terminal.... still running, negative terminal..... still running, finally pull plug on the coil pack!! WTF
Old Jul 30, 2009 | 03:33 PM
xrmalin's Avatar
xrmalin
Id just swop the whole loom it saves having to splice in if your not sure of the pin outs on the ecu
mark.
mk3ste
Oct 17, 2021 10:09 AM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
Nov 1, 2015 06:53 PM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
