Sapphire Cosworth 2wd - Gear Selection Problem
Old Jul 23, 2009 | 02:35 PM
paulshears's Avatar
paulshears
Default Sapphire Cosworth 2wd - Gear Selection Problem
Won't down shift from 5th to 4th
Will shift to 2nd & 3rd from 5th with no problems
With the clutch depressed it will go from 5th to 3rd then into 4th
Old Jul 27, 2009 | 02:26 PM
paulshears's Avatar
paulshears
Old Jul 27, 2009 | 04:37 PM
jon@work's Avatar
jon@work
syncros worn - usual T5 problem
get it rebuilt
Old Jul 28, 2009 | 09:06 AM
AS above but first try a heavy grade GEAR OIL, not the ATF crap, as this will help the synchro's no end, try applying gentle pressure blip the throttle on change down and you will be able to catch it as it slows.
Old Jul 28, 2009 | 09:23 AM
LHD220Turbo's Avatar
LHD220Turbo
i had the same problem on the same gear and it was the baulk ring - either way; it ideally needs rebuilding
Old Jul 28, 2009 | 12:40 PM
Yura's Avatar
Yura
which oil can you advice, as I know T5 use ATF only...
Old Jul 28, 2009 | 01:50 PM
rs2klee's Avatar
rs2klee
K***LMT
mine dont like 3rd to 4th but sometimes does go in ok, so probly on it way out
Old Jul 28, 2009 | 04:42 PM
LHD220Turbo
75w90; but its thicker than atf so from cold gear changes will be harder/ more difficult until the oil warms up
some use gear oil rather than atf if the box is worn
Old Jul 29, 2009 | 06:12 AM
75W90 is what I use, as said a bit clunky for the first 1/2 mile or so, but as it's not as slippery as ATF it helps the synchro's, although my 160,000+ miles box has now totally demolished 3rd gear rings!!
Old Jul 31, 2009 | 03:03 PM
paulshears's Avatar
paulshears
Thanks for the replys
I'll stick some 75W90 in
Also, my Dad's going to check the clutch (he thinks its "dragging")
Probably get him to put the 75W90 in..... save's me getting my hands mucky
Old Aug 1, 2009 | 03:00 PM
It may have overadjusted and be dragging, just slacken the adjuster off at the pedal and it will readjust.
To do this lift the clutch pedal, then with your thumb/finger on other hand push the quadrant at the top of the pedal forwards so it slackens the cable, let go pump a few times and it will readjust.
I've found with cossie clutches you can't do a lazy change and do need to use every last mm of pedal movement, found this out as my left leg is 1 1/2" shorter than my right and I need a block on there like on me pedals on first bike!!
Old Aug 1, 2009 | 09:29 PM
paulshears's Avatar
paulshears
I'll try that first off
guna have a play tomorrow
cossynut2
Aug 19, 2015 11:29 AM
Aug 14, 2015 07:29 AM
pegaz
Aug 12, 2015 07:30 AM
yawiejon
Aug 10, 2015 08:12 PM
Old ford
Jul 31, 2015 06:50 AM
