cossie piston advice
Old Dec 14, 2004 | 09:14 PM
rs nuts's Avatar
rs nuts
Default cossie piston advice
are 4x4 pistons the same as 2wd pistons
reason asking i have damaged the crown of number 4 piston with a snapped valve and i have some standard 2wd pistons in my shed
can i swap the crown of the piston onto my rod out of my 4x4
they are both standard size pistons
Old Dec 15, 2004 | 12:22 AM
Alvyn's Avatar
Alvyn
Default Re: cossie piston advice
[quote="rs nuts"]are 4x4 pistons the same as 2wd pistons
NO their not the same(although they can be used) BUT the gudgeon (spl) pin position is different on the 4x4 piston as it stopped or reduced the amount of piston slap which was an improvement design to rectify the fault in the 205's when using 2w/d pistons. if you get what I mean
Old Dec 15, 2004 | 07:00 PM
rs nuts's Avatar
rs nuts
cheers m8 ive got hold of a 4x4 piston now
jessie_rs
62
Aug 6, 2019 09:27 PM
locum8
Sep 14, 2015 08:45 PM
CrOwSoN15
Sep 14, 2015 11:33 AM
ajamesc
Sep 8, 2015 06:51 PM
Thanasis
Sep 7, 2015 07:33 PM
