Earth connections L8 ECU
Old Jul 13, 2009 | 08:59 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Default Earth connections L8 ECU
I like to know where the actual wires from the ECU for pin 1 and 19 for grounding the ECU are attached to the chassis. When measuring these two points towards the chassis of the car I get a 0.3-0.4Volts differents so the earth connections are not perfect.
Who can tell me where in the car these wires from the harness are attached? It's a Ford Sierra Cosworth 4x4.
Old Jul 13, 2009 | 09:11 AM
Stu @ M Developments's Avatar
PassionFords Creator
They are earthed to the plenum. 2 brown wires at the throttle hanger.
Old Jul 13, 2009 | 09:26 AM
YBJ's Avatar
YBJ
Thinking Cosworth..
Thanks Stu for this quick answer!
Old Jul 13, 2009 | 10:04 AM
silky16v's Avatar
silky16v
Get on That!
I thought that was for a 2wd loom STU?
All 4x4 saph looms i've had the earth is attached via a bolt that fixes the 2 parts of the plenum chamber together but not at the throttle cable hanger its further back toward the bulk head behind the throttle body and to the back & bottom of the plenum (1 bolt back & bottom from the end of plenum if my memory serves me right)
I've always personally run an extra wire from the plenum to the negative side of the battery
Old Jul 13, 2009 | 10:53 AM
Apologies, I just assumed 2wd vehicle and didnt read it properly.
Matt is right on all 4wd variants its on the 2nd to lower last rear plenum bolt.
Old Jul 13, 2009 | 05:19 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
you should never earth these to the battery or connect a spur to the battery from them.
they are earthed in that position to avoid signal noise, which is why ford never earhed them to the battery!
Old Jul 13, 2009 | 06:50 PM
silky16v's Avatar
silky16v
Get on That!
i don't earth it direct to the same point as the loom earth i take it from 1 of the top plenum bolt holes
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
DixieTheKid
11
Jun 6, 2020 11:20 AM
Mark RS
Oct 12, 2015 06:01 AM
griffo69
Oct 4, 2015 11:58 AM
stevecfrst1
Sep 30, 2015 05:18 AM
