iB5 Gearbox sensor
Old Jul 10, 2009 | 02:00 PM
christophe's Avatar
christophe
Default iB5 Gearbox sensor
Anyone know what this sensor in the side of an iB5 gearbox is for? I have another iB5 in my car and it doesn't have it, just a normal reverse switch like an rs turbo box.
I assume its something to do with the reverse light but theres 4 wires coming out and how the hell do you remove it? I cant split the box with it on and dont really want to bust it off!
Old Mar 29, 2010 | 07:50 AM
offitmassive's Avatar
offitmassive
hi there, did you manage to get this sensor out after?? Ive got one to change on the better halfs friends car, as its leaking on the mating face to the gearbox, i ASSUMED it was just undo the 2 torx screws, and wiggle out????
Old Mar 29, 2010 | 11:50 AM
offitmassive
I think i will just remove it, and apply some blue hylomar to stop the leak...
Old Apr 1, 2010 | 05:25 PM
offitmassive
I removed the sensor off, just need to gently wiggle and pull the sensor off, it has a little snap retaining spring on it, so ...just pull it off.
Tried the blue hylomar, had it all blue'd up, still leaks, so a new sensor is needed
Old Apr 2, 2010 | 11:10 AM
martysmartie's Avatar
martysmartie
Might be something to do with reverse wiper function.
Martin
Old Apr 2, 2010 | 01:34 PM
MarkN's Avatar
MarkN
Its a sensor used by EEC - V so it knows which gear you are in I believe.
Old Apr 3, 2010 | 04:44 PM
offitmassive
It only operates when reverse is selected though, its like a ball+socket joint, when reverse is selected, the selector moves to operate the switch, otherwise its does sweet f.a
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
mjonathan24
Oct 29, 2015 10:39 PM
Mark RS
Oct 12, 2015 06:01 AM
Iain Mac
Sep 30, 2015 09:39 PM
stevecfrst1
Sep 30, 2015 05:18 AM
