19cvh fake??????
Old Jul 6, 2009 | 09:41 PM
wozz's Avatar
wozz
Default 19cvh fake??????
hi, i have been offered a 19 cvh..forged pistons,steel conrods,stage 4 head,vernea pulley and lumpy cam.t34 turbo...£800..bargain!!!!
i get my cash out of the safe,jump in my truck and head off up the m6 to collect my engine..157 miles later i arrive meet the bloke and walk to his garden shed...he had took the head off (thank feck) so i could have a look..
this is what i have come home with a greatly reduced price!!!
19 cvh bottom end (very rare as it says 16 on the block???on the top of the pistons it says A 0.50...and on the inside of the piston it says K.P 88 2569..the rods look stock to me...
a head with 42mm exhaust valves and 37mm inlet..
a blue vernea pully
and a turbo in mint condition i cant identify...
ok chaps after seeing all this i got a little grumpy to say the least.i think after a little heated debate i came away with all this because i didnt want a wasted journey and no engine to rebuild....
from what iv listed what am i playing with?? also how do i identify a t34 turbo???..weres the cheapest and best place to get forged pistons and steel rods from...
cheers woz
Old Jul 6, 2009 | 10:36 PM
muz's Avatar
muz
Wye Valley Hardcore
Sounds ike it just a .5 overbored 1600
Old Jul 7, 2009 | 06:16 PM
wozz's Avatar
wozz
any chance of some replies ya misreble feckers!!!!!!!!!!
Old Jul 7, 2009 | 06:20 PM
ScORTED's Avatar
ScORTED
Project Money Pit
PE did a S2 conversion which converts a 1.6 block to a 1900 capacity god knows what you've got though, take loads of pictures and we'll try to help
Old Jul 7, 2009 | 06:49 PM
g1234's Avatar
g1234
if you wanting a 1900 bottom end power engineering i have one cheap that needs rebuilding it detonating on 1 piston i took it to norris motorsport a nd he said he can suply everything for it and reasonable priced for bits can have bottom end cheap
pm me if you want to no costs what quoted will have a mint solid bottom end to start with
Old Jul 8, 2009 | 08:03 PM
frsjon's Avatar
frsjon
the easy/quick way to check if its a long stroke 1.6..(e.g 1.9).would be to take the sump off and look at the rod bolts... as they use the 1.8 cvh crank and rods the rod bolts will be of a stud and nut configuration..and to check the turbo most stock t34's have a raised rectangle section on the compressor housing...hope this helps
Old Feb 14, 2010 | 07:18 PM
dhutch's Avatar
dhutch
How did this end up?
- As said, if its a 1,9 the way to tell if the heads off id to measure the stroke.
- Something i keep meaning to do with mine but as it runs the head stays on!
Old May 1, 2010 | 10:41 PM
dhutch's Avatar
dhutch
No, no leads, not photos. no outcome?
I saw a 1900 PE kit on ebay (used rods/pistons/crank without block) saved the photos to compair with myown. However annoying in the time between saving them and finding the photos i took last time i had the sump off ive actually now lost the photos from ebay to compair them. However,this is a shot from the bottom of my proberbly PE 1900 cvh.
http://img20.imageshack.us/g/dscn6541f.jpg/
Daniel
Old May 1, 2010 | 11:01 PM
Chip's Avatar
Chip
*** Sierra RS Custard ***
just measure the stroke by seeing how far the pistons go up and down the block
Old May 1, 2010 | 11:19 PM
dhutch's Avatar
dhutch
Yes, clearly that would be the definitive method of working out the size. Unfortunately when i had the sump off i was slightly pushed for time and working in the dark. But i guess it should be possible to get a stoke/bore measurement from underneath without taking the head off.
Clearly the OPs head is (or was 6 months ago) off mines not and you can really get a good line onto the piston through the spark plug hole for the sort of accuracy that would be needed to define the stroke as being that of a PE 1900 or a normal 1600.
Otherwise it would also be possible, for the cost of a head gasget, to take the head off and be done with it. While also confirming the TDC mark. Probably replacing the bolts with non-stretch bolts.
Daniel
Old May 1, 2010 | 11:28 PM
Chip's Avatar
Chip
If the head is on, you just stick a mcdonalds straw or whatever down the plug hole onto the piston, so you can see how far it moves, but in this case it sounds like the head is off anyway.
TIFF
Jan 27, 2006 07:43 PM
Gra
29
Oct 14, 2005 02:13 PM
Gra
12
Jan 6, 2005 09:45 AM
soulweavers
11
Sep 18, 2004 09:34 PM
Deano
13
Sep 9, 2004 09:18 PM
