bleeding front brakes
Old Jul 6, 2009 | 11:17 AM
Phil2002's Avatar
Phil2002
Default bleeding front brakes
on a 2wd saff cos when bleeding the front 4pots does the ignition need to be on so that abs pump is running or do you bleed them with ign off???
cheers,
Phil
Old Jul 6, 2009 | 12:12 PM
Ignition does indeed need to be in position 1 so abs valves are open, I just disconnect the actual motor wire, then pressure bleed with me gunsons eezibleed.
Old Jul 6, 2009 | 12:28 PM
dojj's Avatar
dojj
Resident Wrestling Legend
not on the fronts mate, just as normal
just make sure that you do both nipples one at a time inner and outer and then once again, just to make sure
Old Jul 6, 2009 | 02:36 PM
I just assumed it did, I always do all mine at same time when change fluid every 6 months, but did think afterwards it was one end only needed, but wasn't sure at all.
Old Jul 6, 2009 | 03:02 PM
dojj's Avatar
dojj
the front's are as normal, the pump just provides "assistance" in the same way a servo would
the rears are presurised by the pump not your foot ont e pedal, so that's why they are a pain in the arse and require fiddling with
Old Jul 6, 2009 | 08:16 PM
Phil2002's Avatar
Phil2002
sweet cheers for that. another job to do this weekend.
Thanks,
Phil
original
Jan 30, 2022 08:20 PM
Gaz 88
Ford Focus RS Parts for Sale.
29
May 10, 2017 12:31 PM
SmudgerByName
52
Jul 28, 2016 06:14 PM
3drRich
Sep 13, 2015 07:32 PM
Aug 10, 2015 12:08 PM
