L8 ECU red or green
Old Jul 1, 2009 | 04:40 PM
IAN RS2k's Avatar
IAN RS2k
Default L8 ECU red or green
I have a level 8 ecu with a baby pectel board how can I work out if it is a green or red to as the sticker is missing on the cover on the inside the flat upright bits on the circuit board are black & I have seen some with cream ones
IAN
Old Jul 1, 2009 | 06:02 PM
jon@work's Avatar
jon@work
the only difference is the chip
as it's running a pectel board, it all depends on who wrote the chip if the lambda is required or not
Old Jul 1, 2009 | 10:00 PM
IAN RS2k's Avatar
IAN RS2k
Is that the difference one has lambda & the other does not?
IAN
Old Jul 2, 2009 | 07:10 AM
oldford's Avatar
oldford
Yes. And the software dictates whether or not a lambda has to be present.
The hardware is the same for both.
Old Jul 2, 2009 | 09:14 AM
IAN RS2k's Avatar
IAN RS2k
So is the main board the same so its just the chip plus is there a way of telling what mine started life as
IAN
Old Jul 3, 2009 | 11:39 PM
JTECH James's Avatar
JTECH James
Passion for Fords!
yes, the ecus are exactly the same,
the chips are the only difference
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
timsrs
Nov 13, 2018 11:48 AM
griffo69
Oct 4, 2015 11:58 AM
