which cam??
Old Jun 20, 2009 | 07:53 PM
Brian's Avatar
Brian
Default which cam??
im just in the process of an engine rebuild on a frst the head has a piper cam 285t2 ive been told this is to harsh for what power im looking for
im looking for around 185ish any help would b good
brian
Old Jun 20, 2009 | 08:14 PM
Will be fine, very good cam.
Old Jun 20, 2009 | 08:19 PM
RST's Avatar
RST
Looking to put that in mine mate. heard good things off Joe etc...
Old Jun 20, 2009 | 08:23 PM
Brian's Avatar
Brian
With the spec i running (steel rods, wossner pistons for low comp on OFAB with 195 super chip) i have been told i need to run a Kent CVH35?
Brian
Old Jun 20, 2009 | 08:31 PM
s1cab's Avatar
s1cab
285t2 is good ive got 1 in mine. i just found piper springs abit weak, so got double valve springs. i was getting valve bounce. may of just been a dodgy set though..??
Old Jun 21, 2009 | 08:29 AM
Whoever told you that is wrong.
The cvh cam is a "harsher" cam, being 276 degrees, inlet/exhaust, against 262 inlet, 270 exhaust of the T2, lift on both is almost identical, as a next step up from the T2 I would advise the cvh35.
Old Jun 21, 2009 | 08:31 AM
Brian's Avatar
Brian
Thanks for the info
Brian
Nov 1, 2015 06:53 PM
Mc5506
Oct 5, 2015 09:57 PM
