door wiring saph cossy
Old Jun 18, 2009 | 10:01 PM
ItsNothingWithoutATurbo's Avatar
Default door wiring saph cossy
since re shelling my cossie i have 1 red wire in each front footwell which have come from the front doors and i think are for the electric wing mirrors. they have female bullet conectors on the end. i cant find were they are ment to go. are they noramally redundant.
also the anoying buzzer keeps going off when i turn my lights on does the system know the doors are open from the door switches or the door locks themselves?
hope that makes sence.
thankyou
Old Jun 19, 2009 | 10:30 AM
jon@work's Avatar
jon@work
There is a joint in the door that joins the spare red wire you've got to the other red wire that goes into the door. They (or "it" in your case as one is not connected) feed both the electric mirrors (that's the connector with the violet wires in it) and the central locking motor (that's the connector that contains the white and yellow wires). I don't see a problem if you leave it disconnected, but wrap it in tape or heatshrink so it doesn't come into contact with earth.
Old Jun 19, 2009 | 10:36 AM
so they're ment to be permanant live?....
as it would explain wht the central locking isnt working neither are the mirrors?
thankyou
Old Jun 19, 2009 | 01:15 PM
jon@work's Avatar
jon@work
yeah - permanently live through fuse 10
Old Jun 19, 2009 | 04:22 PM
ok thanks i'll have to find it or run a new one through as i cant see it anywhere and i dont feel like taking the dash out again.
thanks
Old Jun 19, 2009 | 05:43 PM
jon@work's Avatar
jon@work
Why run a new wire ? If you've got a red/orange or red/yellow or similar red running to the door that also contains a yellow wire and a white wire, then this is also fed from fuse 10 and will feed the mirrors and central locking. Just check that this wire has permanent 12V to it. If so, then just tape up the loose single red wire you've got.
Old Jun 19, 2009 | 09:05 PM
ah ok i'll do that. im still waiting for my multi meter back i lent to a friend.
DixieTheKid
Jul 23, 2023 10:16 AM
lukeeboy149
Aug 22, 2015 04:29 PM
kosienutter
31
Aug 22, 2015 09:55 AM
gcfcos
118
Aug 18, 2015 05:53 PM
y4n
Aug 17, 2015 12:12 PM
