Battery light comes on when ignition turned off...
Old Jun 14, 2009 | 11:50 PM
Ade's Avatar
Ade
Fast Ford snapper
Default Battery light comes on when ignition turned off...
The battery light has started coming on when ignition is turned off on my Saph...
Just disconected the battery tonight so not to run it flat. Any ideas what would cause this?
Old Jun 15, 2009 | 01:32 AM
jon@work's Avatar
jon@work
does the light stay on if the blue wire is disconnected from the alternator ?
alternatively, does it go off if you pull fuse 22 ?
Old Jun 15, 2009 | 08:03 AM
Ade's Avatar
Ade
Fast Ford snapper
No change with fuses pulled, must be the alternator..... anyone got one?
Old Jun 15, 2009 | 11:49 AM
GLSMAR's Avatar
GLSMAR
had this too before - defo alternator - regulator goosed.
Old Jun 15, 2009 | 12:00 PM
bezo's Avatar
bezo
powered by K26
youve only had it 5 mins and youve broke it already?!?!?!?
Old Jun 15, 2009 | 12:16 PM
Ade's Avatar
Ade
Fast Ford snapper
Could have been worse, I was doing this yesterday after all
Old Jun 15, 2009 | 12:33 PM
bezo's Avatar
bezo
powered by K26
taxi for brannan!
Old Jun 15, 2009 | 08:27 PM
cabriolet's Avatar
cabriolet
done a diode in the alternator fella get a recon
Old Jun 15, 2009 | 09:26 PM
andyuk's Avatar
andyuk
Default light
try pressing the break pedal when ignition off, see wot happens if it changes try lookin at earths!!
Old Jun 15, 2009 | 09:48 PM
Ade's Avatar
Ade
Fast Ford snapper
Bunged an alternator on it, all fixed!
van_dogg_pavvy
Mar 3, 2016 09:30 AM
The Underdog
29
Sep 7, 2015 09:49 PM
ar4ibaldo
Ford Focus ST
Aug 18, 2015 04:24 PM
tankybaby66
Aug 9, 2015 07:13 AM
xr_craig
Aug 7, 2015 06:00 PM
