help please compression ratio for a 1.8zvh???
Old Jun 10, 2009 | 12:27 PM
nick fiesta rs's Avatar
nick fiesta rs
nick
Question help please compression ratio for a 1.8zvh???
hi i have a fiesta turbo with a 1.8zvh it has decompression plate biege injectors t3 turbo double cap itercooler k&n full stainless and up rated fuel pump i been trying to get a chip to run it contacted evoution chips told them the modifications as above and they asked for the compression ratio i said i dont no they said we wont do u one its to dangerous i have no idea wot it is so can any one help its all i need just fully restored my car been waiting 3years and cant wait to drive it all it needs is moting but i dont want to drive it running standerd set up please help
Old Jun 10, 2009 | 03:35 PM
siward's Avatar
siward
You would need to know what pistons you have and the size of the decompression plate to have a chance of working out the cr. If they are standard zetec pistons you can find out what the standard cr is and go from there
I am sure someone else will have a better idea.
Si
Old Jun 10, 2009 | 09:31 PM
nick fiesta rs
nick
ok thanks no one seems to be able to help so far had no reply as far as i no there standerd zetec pistons do you no how to find out the size of plate it has a head gasket either side of the plate cheers nick
Old Jun 10, 2009 | 09:34 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
the compression ration should have been checked be for the engine was built
Old Jun 10, 2009 | 09:43 PM
nick fiesta rs
nick
yeah but i bought the engine off some one that works at mtec automotive but he tells so many lies he says that with the standerd ecu u just turn the boost up and ecu adjusts fuel to suit it and says it will run fine which is rubbish it that was true u wouldnt need chips and the scary thing is he is a rolling road and re maping specailst so still need ratio and have no clue all this is new to me
Old Jun 10, 2009 | 09:45 PM
forevaford's Avatar
forevaford
tell them about 7.5;1 that ul do
Old Jun 10, 2009 | 09:48 PM
nick fiesta rs
nick
will that be safe?is that inculding the plate or just the zetec? cheers nick
Prickly_buzz
Dec 7, 2017 09:52 PM
Nov 1, 2015 06:53 PM
Fezman1
Oct 2, 2015 01:22 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
