mk6 1.8 td tuning help please??
Old Jun 6, 2009 | 03:12 PM
sams td's Avatar
sams td
Default mk6 1.8 td tuning help please??
hiya guys i have a mk6 1.8 td and want to get more power out of it...
i have put a huge k'n filter on it with a cold air suply and i have a bleed valve on the way and a dump valve which i havent got a clue where either goes so im gunna need sum help with that
also.......does anyone have any other tips to get more power
cheers sam
Old Jun 6, 2009 | 06:14 PM
jammerrs's Avatar
jammerrs
exhasut?
more fuel?
but it think heat wrapping and loosing weight would be the easiest/cost effective mods
Old Jun 6, 2009 | 06:17 PM
pani_k's Avatar
pani_k
PassionFORD Member
Doesn't nobody offer flash tuning or a tuning box for these?
Old Jul 3, 2009 | 07:06 PM
dan 1536's Avatar
dan 1536
bigger intercooler n front mount it, bigger boost pipe, i put a mondeo td eng in my van n changed gear box n it went ok
Old Jul 4, 2009 | 07:05 AM
Air side is not really going to do anything on a diesel, so concentrate on upping pump pressure, a lot easier on some than others Lucas(cav) are easy though.
Old Jul 8, 2009 | 12:49 PM
TTommy's Avatar
TTommy
if you have the right injection pump you can ajust it to allow more fuel in. it will become smokey though.
a small ajustable restrictor in the wastegate pipe will allow you to raise the boost as well.
its abit micky mouse though, hard on the engine and smokey. especially off boost.
Old Jul 8, 2009 | 12:50 PM
TTommy's Avatar
TTommy
and put the dump valve in the bin.
its a derv you dont need one.
Daniel Howard
Ford Classics & Vintage
Oct 3, 2015 10:44 PM
SMILER258
Sep 28, 2015 09:04 AM
liamT74
Sep 23, 2015 10:24 PM
talon1
Sep 15, 2015 10:27 AM
natehall
Ford Focus (All Models)
Sep 8, 2015 05:13 AM
