cosworth missfire
Old May 31, 2009 | 11:37 AM
antbrant2000's Avatar
antbrant2000
Default cosworth missfire
I have a saphire cosworth with a bad misfire at idle and up to 2000 rpm . The plugs are new and injectors new , where do i start looking
Old May 31, 2009 | 01:23 PM
grcossie's Avatar
grcossie
Check phase and crank sensor
Old May 31, 2009 | 03:53 PM
If it's ok after 2000rpm I'd also look at the co.
Old May 31, 2009 | 09:36 PM
forevaford's Avatar
forevaford
compression?
head gasket?
Old Jun 2, 2009 | 06:55 PM
antbrant2000
what is the gap supposed to be on the sensors , after 2000 rpm the car pulls well and clear
Old Jun 2, 2009 | 07:30 PM
Phase sensor is 0.2mm to 0.3mm
Crank sensor is 0.6mm to 1.0mm
Old Jun 3, 2009 | 04:53 PM
antbrant2000
thank you i will pull the feeler gauges out and start measuring
Old Jun 8, 2009 | 01:01 PM
davidt's Avatar
davidt
Had the same problem. Changed every sensor plugs, leads, cap and in the end found the fuel pressure regulator vacuum pipe connector was sending fuel back into the plenum. changed the regulator and cured the problem.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
