help to diagnose crack in block
Old May 27, 2009 | 08:49 PM
RSLUBBY's Avatar
RSLUBBY
Default help to diagnose crack in block
What is the easiest way to check a block for cracks without taking it out is there trace dye you can put in etc.
Ian
Old May 28, 2009 | 09:34 PM
hoggath-motorsport's Avatar
hoggath-motorsport
Got the RS Bug
if the car is still running you can use a block tester. type in block tester on that online auction site.
Old May 29, 2009 | 09:53 AM
LHD220Turbo's Avatar
LHD220Turbo
you can buy block tester fluid/ kits; basically you run the car and put a tube in the header tank and fill with a fluid, if the fluid changes colour you've got a problem
the only issue with using this fluid, it not only detects cracked blocks, it also detects cracked heads, warped heads & gasket leaks (especially head gaskets)
Matt
Old May 29, 2009 | 09:54 AM
LHD220Turbo
looks like this
Old May 29, 2009 | 10:29 PM
Barry R's Avatar
Barry R
Hows does that work cos I think my head gasket is leaking oil on the inlet side
Old May 30, 2009 | 07:25 AM
LHD220Turbo
it detects exhaust gases in the header tank, the fluid turns to yellow if detected
Old May 30, 2009 | 09:05 AM
RSLUBBY's Avatar
RSLUBBY
I just need to determin if its the block or head still running was going to take head off and send it away and then try and check block. Had the head sent off found a little crack had it repaired and put it back on blew head gasket within 20 miles. So not taken it apart yet but will be soon.
Ian
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
AJC
Oct 1, 2015 06:47 PM
muzzman1
Sep 30, 2015 08:59 PM
20/20 vision
Sep 29, 2015 11:27 AM
