non starter
Old May 27, 2009 | 03:22 PM
mark r's Avatar
mark r
Default non starter
hi im having trouble starting my 3dr.car has not been started for 4-5 yrs.i bought the car with broken engine.
i have since put my 4x4 engine and l8 ecu in but car wont start.
i have power at ecu and at coil but no power at fuel pump or no spark.
can anyone give me any ideas to where i should be looking to help me get car started
cheers mark
Old May 28, 2009 | 05:42 AM
Did you use the L8 ecu/engine loom, and tps ?
I would check the CPS as this will knock out both if not working, it is possible to misconnect it with the dizzy so worth a check, the pump should go once turning so long as getting a cps signal.
Most likely a small daft bit that's stopping it, so just a general recheck too of wiring at plug into main loom on area around bottom of screen inside car.
Old May 28, 2009 | 08:29 PM
mark r's Avatar
mark r
hi tabetha thanks for reply.do i have to use the l8 engine loom? as i have been told only to swap around outer 2 wires of throttle position switch.(was thinking about knock sensor)
today i put l1 back on with 2wd tps and swaped back outer 2 wires of tps and tried.
i now have spark and fuel pump after cleaning lots of contacts and fuses but as with l8 no injector pulsing.is there a fuse or relay for the injectors?
Old May 29, 2009 | 01:15 PM
akamob's Avatar
akamob
It started. But with his L1 and not the l8
Old May 29, 2009 | 03:39 PM
mark r's Avatar
mark r
yes it has started today finally with l1 2wd tps and yellow injectors.but i do wanna run the l8 as i have a chip for greens an 3 bar map sensor and injectors.do i as you suggested tabetha use the 4x4xengine loom to get car running with l8 or is there any way i can run car without changing loom
cheers mark
A.t.p
Oct 23, 2015 07:54 PM
cossie362
Oct 11, 2015 03:53 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
marky_g
Sep 12, 2015 04:26 PM
