Lsd or not ????
Old May 26, 2009 | 07:34 AM
CHUNKYS RS's Avatar
CHUNKYS RS
Default Lsd or not ????
hi i have just taken the gearbox out of my frst to replace some seals is there an easy way to tell if it has a lsd fitted
Old May 26, 2009 | 08:24 AM
DarrinDD's Avatar
DarrinDD
you can do it when the gearbox is on the car!
jack the front end up and spin the wheels. if they both spin the same way then its got an LSD, if the other wheel spins the opposite way its a normal one...i think lol
Old May 26, 2009 | 08:46 AM
bookwyse's Avatar
bookwyse
If you see through the diff you have a standard one, id you can see a plate with a circular hole then you have an LSD
Old May 26, 2009 | 02:42 PM
CHUNKYS RS's Avatar
CHUNKYS RS
in that case i have a lsd
as i can see a plate with a hole thanks guys
TPM961
Jan 15, 2018 10:50 AM
mk1turboestate
Dec 2, 2015 08:31 PM
155lee
Oct 24, 2015 11:11 AM
dalmarshall
Ford Classics & Vintage
Oct 1, 2015 06:46 PM
fordfiestamk3
Sep 11, 2015 12:52 PM
