noisey tappets
Old May 26, 2009 | 05:41 AM
kosienutter's Avatar
kosienutter
Last Time, Get Off PF FFS
Default noisey tappets
for a month or so my tappets have been not badly noisy but enough to annoy me, you know. Any way yesterday morning i thought ill stretch the cars legs for the first time, since ive owned it as i usually dont go above 4 and a half k. Well i took her to the limiter in 1st, 2nd and nearly in 3rd. When i pulled up in the car park the engine sounded fine. Does that mean it Needed the leg stretch and did it a bit of good, or is it time to change the tappets and followers? cheeRS
Old May 26, 2009 | 09:20 AM
kitted_escort's Avatar
kitted_escort
i would just take it to a garage and get the tappets checked out
Old May 26, 2009 | 09:50 AM
It just means most likely the tappets were not adjusted correctly before, the extra grief you gave it thinned the oil a bit more and helped loosen any crud that was in them, they are ok to leave as is, it should be pretty quiet.
Old May 26, 2009 | 11:53 AM
martysmartie's Avatar
martysmartie
Has it been sitting for a while? As they are hydralic tappets the oil may have sluged up and now you have given it a good bootful its cleared it out.
Martin
Old May 26, 2009 | 04:00 PM
kosienutter
it has not sat around i just dont throttle it enough which i guess gave it the sludge aroundthe tappets
Old May 26, 2009 | 05:47 PM
LHD220Turbo's Avatar
LHD220Turbo
probably just needed a good blast
as tabs says, the hotter the engine gets the thinner the oil, probably done it a world of good
Old May 26, 2009 | 07:13 PM
kosienutter
happy days.
davidfordrs
Sep 21, 2015 04:23 AM
Roosie
Aug 13, 2015 07:40 PM
RScrew69
Dec 4, 2004 05:25 PM
SPADGE
11
Sep 13, 2004 04:15 PM
Mar 12, 2004 08:53 PM
