2wd or 4x4 intercooler ?
Old Oct 12, 2003 | 09:39 AM
steveRS's Avatar
steveRS
Default 2wd or 4x4 intercooler ?
dont want to seem thick but
how do you tell the difference between 2wd and 4x4 intercooler?
thanx
Old Oct 12, 2003 | 09:50 AM
rsjohn's Avatar
rsjohn
Steve you have a 4x4 cooler on yours, the dump valve take off on 4x4 goes straight up and 2wd is angled.
As i see you have gone stage 3 you need to get an rs500 type intercooler.
John.
Old Oct 12, 2003 | 10:06 AM
Stoned's Avatar
Stoned
2wd Cossie:
10 cm high (top to bottom)
60cm long to its furthest opposing points
10cm deep (front to back)
41cm actual core length.
4wd Cossie:
11.5 cm high (top to bottom)
66cm long to its furthest opposing points
12.25cm deep (front to back)
45.5cm actual core length.
Old Oct 12, 2003 | 10:52 AM
steveRS's Avatar
steveRS
thanx lads
excellent pic very helpful
rsjohn hows it going m8
indeed stage 3 engine sound
regards
steve
Old May 3, 2007 | 11:33 PM
phill295's Avatar
phill295
the 4x4 item is larger thats it really
Old May 4, 2007 | 06:58 AM
4x4 is larger as sadi but the actual CORE is not THAT much bigger, 4x4 one also has plates on the end to stop air in gap where as 2wd one does not.
Ridgey
12
Nov 2, 2015 06:54 PM
155lee
Oct 27, 2015 04:55 AM
mark r
Sep 29, 2015 07:27 PM
simonmcf
Sep 22, 2015 08:40 AM
tib2220
Sep 14, 2015 12:33 PM
