running problem
Old May 20, 2009 | 10:00 PM
simmons504's Avatar
simmons504
Default running problem
hi there ive got a frst starts fine and ticks over. when you put your foot on the throttle it wants to cut out but if you rev it up slow it will rev rite to the top end any ideas thanks matt
Old May 21, 2009 | 05:57 AM
Running VERY weak, check CO, probably better when cold ?
Old May 21, 2009 | 05:03 PM
simmons504's Avatar
simmons504
after the fuel pump has primed up with ignition on (not running) should you be able to hear fuel running into the tank?thanks simmons504
Old May 24, 2009 | 02:40 PM
simmons504's Avatar
simmons504
is any 1 selling a frst fuel pump
Old Aug 16, 2009 | 10:35 AM
glover's Avatar
glover
i have the same problem with the 2wd i just bought will tick over for 30 secs or so then just stop once you turn the key again it will fire up no bother also when you try to rev it it will cut out you have to rev it a few times to get it to drive. i dont know what its like to drive on the road as i am doing a lot oif bodywork before the mot.
cheers neill
wheelwizardrefurbs
Sep 23, 2015 09:14 PM
Johnsie
Ford Focus ST
Sep 8, 2015 02:39 PM
kosienutter
31
Aug 22, 2015 09:55 AM
Stu @ M Developments
41
Aug 21, 2015 06:47 AM
Zoggon
Aug 10, 2015 10:39 AM
