removing sump off a 1.8 diesel engine!!
Old May 15, 2009 | 09:41 PM
orion_crazy_carl's Avatar
orion_crazy_carl
orion=mini saff
Default removing sump off a 1.8 diesel engine!!
gotta change the sump gasket on my old dears R reg fez, i took all the bolts out of the sump, but it wont come off!!!im guessing its bolted inside the Gbox to, if i take all the bolts out of the box, can i get enough space to undo the bolts????I really cant be arsed to take the box out again
Old May 15, 2009 | 10:04 PM
saph4be's Avatar
saph4be
box out and flywheel off iirc mate
Old May 15, 2009 | 10:05 PM
orion_crazy_carl
orion=mini saff
in that case, fook, balls, wank biscuits
Old May 15, 2009 | 10:27 PM
steves24V's's Avatar
steves24V's
As above fuck balls wank, sorry i mean gearbox out clutch off flywheel off 2 bolts out
Old May 16, 2009 | 08:07 AM
JonathanJ's Avatar
JonathanJ
I thought if you took the shield off betwwn engine and box you could get at the 2 bolts at the end of the sump , sure I did it that way inthe past , but you never know I have been wrong before
Old May 16, 2009 | 08:30 AM
steves24V's
On a 1.8 d there is a housing round the rear main oil seal, this is bolted to the end of the block and end of the sump so not allowing the sump to come down. iirc.
Old Jun 1, 2009 | 02:17 PM
orion_crazy_carl
orion=mini saff
just to update,wht a fooking shit wank idea
4 bolts under the flywheel, pain in arse, dont advise neone doing it
RUBY123
Oct 22, 2023 12:04 PM
Aug 29, 2015 08:16 PM
taylora1409
Aug 12, 2015 12:06 PM
knight19770
Aug 4, 2015 12:36 PM
lockie
Jul 31, 2015 10:03 PM
