cosworth tps.......
Old May 14, 2009 | 03:39 PM
saph cos rob's Avatar
saph cos rob
swindon rsoc
Default cosworth tps.......
i read i thread a little while ago about this but cant find it for love or money lol.....
i have tryed to fit a 4x4 tps to my 2wd saph (L6), i switched the 2 outer wires over and when i started it, it ran like a dog.... so i swapped the outer wires back to how it was, it now seems to run ok....
so basically the question is do you only have to switch the outer wires over if your converting it to L8 ecu?
Old May 14, 2009 | 03:43 PM
JokerDisco's Avatar
JokerDisco
If i remember correctly with the 4wd TPS when using a Level 8 or P8 ECU you will need to swap round the outer 2 wires on the TPS Plug.
Old May 14, 2009 | 03:48 PM
saph cos rob
swindon rsoc
yep thats what im thinking.... just everyone has told me if you fit a 4x4tps you have to swap the wire regardless of it being l6 or not....
Old May 14, 2009 | 05:32 PM
oldford's Avatar
oldford
Why do you use the 4x4 tps?
I agree with Jokerdisco, only need to swap the wires if you are going to a L8 or P8 ecu.
Old May 14, 2009 | 05:53 PM
saph cos rob
swindon rsoc
marelli dont manufacture 2wd ones anymore (so ive been told) and i dont like using second hand used sensors lol
Old May 14, 2009 | 08:37 PM
JokerDisco's Avatar
JokerDisco
Don't know about manufacturing them anymore but there is always new ones popping up on ebay and I'm sure they are genuine marrelli ones!
Old May 15, 2009 | 07:50 AM
Just use another make/type with same resistance, it's a standard 8mm "D" shaft connection.
Billy_RS
Sep 13, 2015 04:17 PM
28
Sep 8, 2015 07:10 PM
Adam Graham
Sep 6, 2015 06:04 AM
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
