Problem cahnging gear.
Old Apr 15, 2009 | 05:59 PM
Rs-Simon's Avatar
Rs-Simon
Default Problem cahnging gear.
Hi all. Having an issue with my rst. It had a new clutch 12000 miles ago, and I just fitted a new clutch cable. When its cold to warm changes gear fine, but when it gets hot its a right bastard and wont go into gear. Any ideas?
Thanks in advance.
Old Apr 15, 2009 | 08:30 PM
LHD220Turbo's Avatar
LHD220Turbo
have you got the right oil/ any oil in it?
Old Apr 16, 2009 | 11:13 AM
IANS2RST's Avatar
IANS2RST
warped clutch plate. did you have the flywheel skimmed when the new clutch was fitted?
Old Apr 16, 2009 | 03:23 PM
Will it not go or is it grinding when trying to put in gear, if it's grinding try some new box fluid, if it just doesn't want to go in gear it may be out of adjustment.
DAZZER
Sep 30, 2015 08:43 PM
DavidK
Sep 27, 2015 02:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
Shaunc
Escort Range
Sep 23, 2015 06:00 AM
