Oil Pump
Old Apr 8, 2009 | 09:52 PM
Dearo's Avatar
Dearo
Default Oil Pump
Standard or high pressure oil pump for 2wd cossie stage 3 ??
Old Apr 8, 2009 | 09:56 PM
iansoutham's Avatar
iansoutham
OCD Victim
Standard, and I would recommend going for a genuine Ford one as well.
Old Apr 10, 2009 | 11:45 AM
Dearo's Avatar
Dearo
Cheers mate, at what power should you use a high pressure pump ??
Old Apr 10, 2009 | 02:49 PM
iansoutham's Avatar
iansoutham
OCD Victim
It is about flow as much as pressure.
You can have all the pressure you want, but if it cannot flow quick enough round the engine, then it will be wasted.
I would recommend asking one of the more respected engine builders on here what spec they would recommend before needing a high pressure pump.
Old Apr 10, 2009 | 09:11 PM
Dearo's Avatar
Dearo
Cheers Ian, I'm not going above 340 ish, so I will stick to a standard pump.
155lee
Oct 27, 2015 04:55 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
Eigdoog
48
Sep 19, 2015 11:03 AM
Rich Coveney
Ford Mondeo Including ST
Sep 15, 2015 05:39 PM
