Saph 4x4 Fuel Pump Re-Wire
Old Apr 5, 2009 | 07:37 AM
Its Dave's Avatar
Its Dave
Default Saph 4x4 Fuel Pump Re-Wire
From fuel relay 20amp wire to the pump?
Also at the relay 30 amp to the battery with a inline fuse?
Dave
Old Apr 5, 2009 | 09:43 AM
That would do the job, pump lockout on 044 is 18 amps, so uses less than this.
Don't forget the earth is just as important, I take this straight to the battery, some take it to the bodywork, where rust and resistance can build up.
Ben26
Sep 1, 2015 06:29 AM
ekjim
Aug 27, 2015 05:20 PM
Prickly_buzz
Aug 25, 2015 11:33 AM
kosienutter
31
Aug 22, 2015 09:55 AM
c20tbo
Aug 17, 2015 10:19 PM
