brake problem
Old Apr 4, 2009 | 05:06 PM
dangerousbrian's Avatar
dangerousbrian
Default brake problem
after some advice please people..drove the car the other night and all was well for about half mile.. from then on the front calipers gradually binded themselves on..had to loosen m/c from the servo to get home..i have since adjusted the rod in the servo that pushes the fluid but i cant get the brakes to work...when jacked up the wheel wont turn unless the m/c is loosened and even then its still tight...every part is new so doubt anything is faulty..any ideas? cos its really doing my head in cheers..
escort rs turbo with 4x4 cossie front calipers and standard drums by the way
Old Apr 4, 2009 | 06:27 PM
I would start by freeing off the sticky caliper, then if needed reset the rod.
yatta
May 21, 2016 10:31 PM
morg65
Escort MK 5 / MK 6
17
Sep 11, 2015 08:40 PM
focus2351
Sep 9, 2015 09:33 PM
routemaster
Sep 7, 2015 05:27 PM
cossirob
Sep 3, 2015 09:17 PM
