Cam/crank sensor
Old Mar 31, 2009 | 11:28 AM
Rabbit's Avatar
Rabbit
Default Cam/crank sensor
Installing Autronic SM4 on my 3dr these days and got a 36-1 trigger wheel on the crank.
Will be running 4 coils direct fire.
Whats the best sensors to use on the cam/crank? Standard reluctor or hall effect?
Will probably use the small turbo phase sensor assembly modified to give one pulse per engine cycle (720deg) but open to ideas,..
Old Apr 1, 2009 | 12:38 PM
When I used a trigger wheel on my 2wd sapphy I just used the std ford sensor in the std place/bracket, lined up perfectly.
Old Apr 1, 2009 | 03:58 PM
Mark Shead's Avatar
Mark Shead
You can use the complete Small turbo parts as these work perfect on the standard car.
Mark
Old Apr 1, 2009 | 05:10 PM
Rabbit's Avatar
Rabbit
Thanks for replyes!
Is the crank sensor on the t28 escos hall or reluctor (2 or 3 wires)?
Old Apr 1, 2009 | 05:16 PM
Mark Shead's Avatar
Mark Shead
Thanks for replyes!
2 wire mag.
Mark
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
