Starter Motor switched live feed.
Old Mar 31, 2009 | 09:45 PM
muz's Avatar
muz
Wye Valley Hardcore
Default Starter Motor switched live feed.
I've finally sorted the wiring on my Escort but what AMP wire will I need to run the switched live from the yellow wire on the ignition switch to the starter motor?
My existing wiring doesn't seem to have it.
Also does the blue wire which goes from the alternator for the battery light go from the alternator to the back of the clocks? As it doesn't have that either.
Old Mar 31, 2009 | 10:57 PM
jon@work's Avatar
jon@work
25-30A should be fine. Are you sure you mean the yellow wire on the ignition? I thought that was for accessory feeds (ie key position 1).
re the blue alternator wire : yes
Old Mar 31, 2009 | 10:58 PM
muz's Avatar
muz
Wye Valley Hardcore
No it wasn't the yellow come to think of it. Its the blue and black one IIRC
Old Apr 1, 2009 | 12:36 PM
Just make sure it is defo from the ignition switch as there is another wire exact same colour on a lot of fords, coming from fusebox!!
Old Apr 1, 2009 | 05:33 PM
muz's Avatar
muz
Wye Valley Hardcore
It's all sorted. i'd taped it up in my old loom when I did the cossie managment conversion.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
bobsworth
77
Mar 24, 2016 09:30 PM
A.t.p
Oct 23, 2015 07:54 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
