Sierra Coolant level sensor
Old Mar 28, 2009 | 12:15 PM
stevedohc16v's Avatar
stevedohc16v
Default Sierra Coolant level sensor
I've got a spec R header tank on my saph which must of been for a 3 door as it has the hole for the level sensor, I've got hold of a level sensor and want to wire it up to a warning light on the dash, problem is I cant sus out how to do it.
When the level is ok the switch is made so its not as simple as just wiring a bulb in the circuit as it would be on all the time, the other problem is it wouldnt be that easy as the switch will not pass enough current to light the bulb anyway.
Looking at the wiring diagram the wiring goes to a module, does anyone have any idea what I can do to get it to work, I dont mind a bit of soldering etc, I've had a look inside a couple of warning modules I've got lying around and there is just a microchip in there so I'm thinking I'm screwed for wiring this up?
Steve
Old Mar 31, 2009 | 05:06 PM
Simply use a change over relay, so the switch when broken causes the relay to changeover to other terminal output to which you connect a light.
The sensor will carry enough current for a relay no problem.
15
Oct 7, 2015 03:43 PM
wheelwizardrefurbs
Sep 24, 2015 08:35 PM
Dr. Ickxs
Sep 15, 2015 10:15 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
