needing your help please :(
Old Mar 23, 2009 | 03:02 AM
CRAIG HAYTER's Avatar
CRAIG HAYTER
Unhappy needing your help please :(
Hi there guys i was out in it tonight in tommi mac evo 6 went round a round about (circle) and went over a drain the car started to feel not right and pull to the drive side got it home and jack the car up the wheel is wobbleing and checked the nuts no sound from the bearing but i seen what i think is the Rear traction control arm its an upper arm something that bolts to the car its slackor a bush has went?because it is movingdo they come in all one part?or do you think it will be the bush or something else thats the only part i can see movinggutted can anyone please help and is it a common thing or just wear and tearalso is it an easy job or a nightmare
cheeRS
Craig
Old Mar 23, 2009 | 07:32 AM
I'm not terribly sure, but look up on Powerflex website or superflex etc to see if they list bushes, if they do then you know they are seperate, which is what I suspect, can't see it being much of a job either, just tracking check/adjust afterwards.
Old Mar 23, 2009 | 12:30 PM
CRAIG HAYTER
thanks buddy a got this off a lancer site
Originally Posted by Rob
Craig,
there was a factory recall on the rear arms as they crack on Vi's worth checking if yours has been done? if not could be a free fix
Old Mar 23, 2009 | 02:35 PM
CRAIG HAYTER
they said it would take a few weeks for the to tell me yes or noso it is a common fault£168 fo the armi need to get the car back on the road so going to need buy it mitsi in fifeso iam gutted but the way i look at it better that thn havng my kids in the car and someting serious happening get Baz St to fix it in his garage
JoeyBoyden
Jan 4, 2024 02:36 PM
jessie_rs
11
Jun 3, 2019 04:57 PM
borboyous
Aug 22, 2015 11:17 AM
col93saphcos
Aug 7, 2015 03:21 PM
