atlas axle strip down HELP
Old Mar 22, 2009 | 08:23 PM
fostersice's Avatar
fostersice
Default atlas axle strip down HELP
hi guys
new guy hear who needs your help
just got me self a escort mk2 rs2000
the car has been fitted with
atlas axle with 5 likes and rear discs
im removing the leaf springs and replacing them with GAZ coilovers
anyway the guy who had the car before be had painted the axle in blue
and i want to remove the hard ware that is nolonger needed and have the axle powder coated
ive removed the diff casing
removed the 4 bolts from each end of the half shafts
undone the 4 bolts holding the diff in and the large nut on the prop end
but i can not remove the diff or the half shafts
shoul the half shafts just pull out then remove diff
or am i missing something?
thanks guys
Old Mar 22, 2009 | 08:39 PM
stage 3 muppet's Avatar
stage 3 muppet
Originally Posted by fostersice
hi guys
thanks guys
been a long time but halfshafts should slide out mate ....
not sure if they have locator circlips on them holding them in or not
then same for diff should come out
may have to knock it off though with a hide covered mallet thing lol
Old Mar 22, 2009 | 09:03 PM
fostersice's Avatar
fostersice
thanks mate
i have removed the 4 bolts from each end
and the 4 bolts holding diff in aswell as the front large nuts holding the prop mount on
ive hit the disc mounting huds with hammer and nothing ?
Old Mar 22, 2009 | 09:38 PM
costina's Avatar
costina
Live long and prosper!!
thanks mate
Get some long m10 bolts and put throu the back of axle flange do them up evenly so that the ends are touching back of half shaft tighten up as to push the shaft outwards
As for diff use 2 suitable blocks of wood to lever the diff out
Hope that helps a bit if not borrow a large slide hammer
Paul
mk1turboestate
Dec 2, 2015 08:31 PM
cossie330
Oct 7, 2015 08:22 PM
Mc5506
Oct 5, 2015 09:57 PM
