external wastegate fitting advice
Old Mar 5, 2009 | 09:41 PM
ram's Avatar
ram
Has a large member
Default external wastegate fitting advice
now ive got an external wastegate fitted..and removed the actuator. what do i do with the internal wastegate that has now been made redundant. as its just flapping about now with no actuator holding it shut/open.
do i just remove the whole flap, leaving the internal wastegate open? as the external one has now taken its duties?
hope ive made sense. its for a t34 turbo on an rst if that helps, cheeRS
Old Mar 5, 2009 | 09:47 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
if you remove the internial one it will by pass the gasses all the time so the turbo will make very little boost. you need to weld the internial one shut or leave the actuator on and wined it shut
Old Mar 5, 2009 | 09:54 PM
ram's Avatar
ram
Has a large member
ah ok, i had a 50% chance of getting what to do right, and i chose the open, doh! will just weld it shut then as i cant fit an actuator on a t34 in a fez as it rubs on the rad lol
cheers fella
Old Mar 6, 2009 | 10:38 PM
westus1's Avatar
westus1
any actuator will hold it closed as long as you just leave the vac pipe off of it
or you can just make up a little threded rod to hold it closed
Old Mar 7, 2009 | 12:52 PM
ram's Avatar
ram
Has a large member
cheers mate think il just weld it shut to make it permanent
Old Mar 7, 2009 | 01:21 PM
SillyFezzaMk1's Avatar
SillyFezzaMk1
Rubber Rhino Crew
If you weld it you might get problems in future with it cracking. Bet bet to use a piece of threaded rod like already said.
Also if you weld it it might be hard to sell on if you ever need to.
Dan
Old Mar 9, 2009 | 09:16 PM
ram's Avatar
ram
Has a large member
good point. its round my mates at the mo getting manifold finished. when i get it back il have a look and see best way of fitting a rod to keep it shut.
its only one of those cheap laggy japanese t34s so will prob blow it up before i sell it lol
jessie_rs
11
Jun 3, 2019 04:57 PM
May 31, 2016 09:28 PM
rsstav
Ford Focus RS Parts for Sale.
Aug 20, 2015 07:45 AM
Aug 14, 2015 07:29 AM
Hellraiser
Aug 8, 2015 04:19 PM
