frst engine help
Old Mar 5, 2009 | 09:14 PM
t3lfrst's Avatar
t3lfrst
Default frst engine help
hi guys i took the head off my frst and notised a crack goin along the block and through to piston liner.i got another engine and i am doin the work myself what is the best way of removing the bottom end? ive unbolted it from the gearbox but dont have enough room to fully seperate them to lift the bottom end out?
Old Mar 5, 2009 | 09:16 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
if your doing it that way put a jack under the bellhousing end of the gear box and jack it right up and lift the engine up at an angle with it then it will slide out
you mite have to take the mount off tho
Old Mar 5, 2009 | 09:20 PM
t3lfrst's Avatar
t3lfrst
wicked mate that was fookin quick only posted 2 mins ago thanks alot
Old Mar 5, 2009 | 09:22 PM
clarke5700's Avatar
clarke5700
watch you dont jack it up to far tho as you mite split the cv boot
Old Apr 4, 2009 | 08:16 PM
wino's Avatar
wino
agreed with clarke easiest way support engine on jack take of bottom pulley though to give more clearance hope this helps
Billy_RS
16
Oct 11, 2025 09:41 PM
bigryrs
Fiesta RS1800/RS Turbo
Sep 5, 2015 02:57 PM
rsturbo27
Sep 1, 2015 09:54 PM
bigryrs
Aug 28, 2015 05:32 PM
