Diff ratio ?
Old Mar 2, 2009 | 02:22 PM
xrmalin's Avatar
xrmalin
Default Diff ratio ?
Im in the process of putting a zetec into my mk4 escort estate and i was going to use a mk4 escort xr3i gearbox for it but after taking the 4 speed box out i was wondering if it would make any differance if i took the diff out the 4 speeder and put it in my 3i box ? Ive got my 3i box in bits any way rebuilding it so it will just be a case of taking it out the other box and slotting it in.
cheers mark.
Old Mar 2, 2009 | 09:34 PM
JesseT's Avatar
JesseT
Do you wan't to exchange the diff or the final drive ratio? The diffs are the same and the final drive ratio is the ratio of diff crown wheel teeth count divided by the mainshaft driving gear teeth count. If you want to change the ratio, you need to exchange the mainshaft and the crown wheel. The problem is that your other mainshaft is a 4speed one.
Old Mar 3, 2009 | 12:57 PM
xrmalin's Avatar
xrmalin
sounds like alot of agro i think ill just leave it as it is.
Old Mar 3, 2009 | 04:51 PM
JonathanJ's Avatar
JonathanJ
4 speed mainshaft will not go into 5 speed box as mentioned above , I think you will be better off with the 5th gear as it will be pulling a lot harder aswell , and would thingk the 2 diff ratios would not be that far apart anyways
Old Mar 3, 2009 | 05:13 PM
xrmalin's Avatar
xrmalin
it was just a thought good job i asked then and didnt just do it
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
DavidK
Sep 27, 2015 02:55 PM
IainRS1700T
Sep 25, 2015 06:44 AM
Fezman1
Sep 7, 2015 09:34 PM
