escos breather system
Old Nov 28, 2004 | 10:21 PM
AJ Escos's Avatar
AJ Escos
Default escos breather system
ok here goes, on the small turbo escos you went from both sides of the block (correct ), so on the inlet side do you remove the black oval tin shaped thing completely or what
Old Nov 29, 2004 | 07:59 AM
Alvyn's Avatar
Alvyn
pipes from the new breather goes 1: into the top of the original breather pot and other pipe 2: (oil return)goes into adapter/connector (u will have to put one into the drivers side of engine the hole's already there but has a bung/bolt in it) 3: last pipe vents to atmosphere job done
ps DON'T use silicone hoses for the oil pipes(unless they are the specially made ones for oil as contamination by oil will rot or split them after a while
Old Nov 29, 2004 | 12:55 PM
Dave Henshall's Avatar
Dave Henshall
one goes to where the original breather went (less the std oil seperator (obviously) - blue pipe
then the smaller one is the oil return to the sump - black pipe.
the remove the bung on the turbo side of the block...
connect a nipple in and connect another blue pipe here...
route the pipes through the inlet manifold and round the back of the head...
then the two larg eblue pipes connect to the top of the oil seperator, the smaller black one to the small angled one at the bottom anbd the large one in the bottom gan go to either catch tank or just vent to atmosphere like mine.
Nov 1, 2015 06:53 PM
Turbo1994
Ford Escort RS Cosworth
Oct 17, 2015 10:32 PM
gcfcos
59
Oct 6, 2015 05:04 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
