Engine & Gearbox
Old Mar 1, 2009 | 11:24 AM
Leggetts 4x4 Cossie's Avatar
Leggetts 4x4 Cossie
Default Engine & Gearbox
Hi all,
Im looking for a little help, I have a small dutton pheaton S3 kit car running mk 1/2 escort gear. 1300cc crossflow engine and 4 speed box.
I would like to change the engine for something with a bit more power, something different, im thinking of a escort cvh 1600 cc Turbo from the RS turbo. Would the escort box fit this engine ? if now what gearbox would i need to use to make this work.?
Thanks all.
Old Mar 1, 2009 | 01:33 PM
I would GUESS that the box would fit on, but why not a nice 1700cc X flow, or even a 2 litre X flow, awsome engine, can also use a different crank in it for more cc, think it's a nissan crank but not terribly sure on that.
Old Mar 3, 2009 | 05:33 PM
JonathanJ's Avatar
JonathanJ
The gearbox should fit , the only issue would be the spigot bearing , might need to have the crankshaft machined to allow the bearing to fit , and also it depends on which box you have in there if it is going to be strong enough , which depends on the state of tune that you are aiming for . I would go the EFI turbo route just cos it makes the instalation easier, with probably a T2 as your weight will be low .
SmudgerByName
52
Jul 28, 2016 06:14 PM
van_dogg_pavvy
Mar 3, 2016 09:30 AM
3drRich
Sep 13, 2015 07:32 PM
JoeyBoyden
20
Aug 22, 2015 03:23 PM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
