3dr Cosworth misfire help...
Old Feb 24, 2009 | 05:46 PM
boXXer's Avatar
boXXer
GASH!
Default 3dr Cosworth misfire help...
Hi all, just wondered if anyone could give me a hand or some pointers in how to sort my missfire.
Car was setup last year, and ran fine all summer. Havnt used it for a while, so got it out a couple of weeks ago for a small run. It now has a misfire when on boost.
It was missing @ 15psi, so i changed the plugs to some iridium items, and it was exactly the same. Gapped them down to .8mm and it "moved" the misfire up the boost range to about 19psi. So gapped them down to .5mm, and the misfire moved up again to 26psi.
i have changed the plugs, leads, rotor arm, cap, coil, crank sensor and phase sensor and it hasnt changed anything.
Is there anything else thats worth trying? it seems to me that it has a weak spark, as the smaller you close the gap, the higher boost it reaches.
Cheers for any advice.
Mike
Old Feb 25, 2009 | 03:58 AM
A "group a" coil is worth a try if not already, the std coils really are that crap, also check supply at coil to make sure it is full supply and not got a duff supply.
Old Feb 25, 2009 | 09:18 AM
IANS2RST's Avatar
IANS2RST
also check the alternator output under load
Old Feb 25, 2009 | 10:18 AM
jon@work's Avatar
jon@work
how old is the fuel in the tank ?
it does go stale
Old Feb 25, 2009 | 11:55 AM
boXXer's Avatar
boXXer
GASH!
Its a brand new "group A" coil mate.
boXXer's Avatar
boXXer
GASH!
it does go stale
new fuel mate
Old Feb 25, 2009 | 11:58 AM
boXXer's Avatar
boXXer
GASH!
what does the ignition amp do exactly?
reason i ask is, it seems the smaller the plug gap, the harder the boost "blows out" the spark, like it has a weak spark.
Old Feb 26, 2009 | 08:22 AM
boXXer's Avatar
boXXer
GASH!
up
Old Feb 26, 2009 | 08:27 AM
daviddunlop83's Avatar
daviddunlop83
I had something similiar on my standard 3 door. When driving normally it was fine. Soon as went onto full boost it misfired and put engine management light on.
Turned out the plug that connects to the crank position sensor was f**ked and not contacting properly. The pins inside where spread apart. Bent them together before i could get a new plug and fixed the problem
Old Feb 26, 2009 | 03:26 PM
boXXer's Avatar
boXXer
GASH!
i think i may have fixed it. Did what you said, and cleaned ALL the multi plug connections, and bent the tabs over a little, and it seems to have dissapeared. Will update tonight....
Old Feb 26, 2009 | 03:42 PM
daviddunlop83
Hope it cures your problem. Something so simple can take so long to figure out whats wrong
Old Feb 26, 2009 | 08:44 PM
boXXer's Avatar
boXXer
GASH!
well, its been spot on all night mate, so i hope thats fixed it. Maybe it was a loose/dirty connection?
j.hammond1
30
Oct 31, 2021 05:28 PM
JK12
33
Apr 26, 2021 12:09 PM
tonicosworth
Ford Escort RS Cosworth
Oct 31, 2015 08:40 AM
Aug 14, 2015 07:29 AM
taylora1409
Aug 12, 2015 12:06 PM
