Where do I put a bleed valve?
Old Feb 24, 2009 | 04:59 PM
godzilla's Avatar
godzilla
Default Where do I put a bleed valve?
I bought a bleed valve for my workhorse, a 1998 Toyota Avensis Estate 2.0 Turbo Diesel.
Where do I put this bleed valve? There is the Turbo then a smallish black hose that runs from that to the actuator. Do I put it in between the Turbo and actuator on that hose? Also how many turns shall I turn it to, not got a boost gauge so its going to be trial and error, well I hope not error as dont want to melt my engine!!
Also!! Would an induction kit help a Turbo Diesel car? I know it may sound strange wanting to do up my Toyota Avensis Estate but the performance is dull! I have an almost new Pipercross induction kit for a Mondeo 2.0 16v hanging around in my garage which I thought I could use, and the bleed valve, well £14 off Ebay!! So if I can get around 10bhp that would be for £14!!
Old Feb 24, 2009 | 05:15 PM
G420 DEL's Avatar
G420 DEL
yeah in the pipe from turbo to act.. but you really do need to adjust the fuel to match. cant just turn up the boost and expect the fuel to match.
Old Feb 24, 2009 | 05:18 PM
KSA-Cossie's Avatar
KSA-Cossie
In the bin.
Old Feb 24, 2009 | 06:41 PM
godzilla's Avatar
godzilla
Originally Posted by KSA-Cossie
In the bin.
Oh..... are they bad?
So I cant just adjust boost and expect gains, need to adjust fuel aswell?
Excuse me if sound thick.....not the best on this kind of thing!!
Old Feb 25, 2009 | 03:46 AM
They are also known as killer valves, more so because people just put them on, whack up the boost and say wahay this is great, then bang!! piston melted.
As said fuelling needs upping to suit increased air flow, I would save up for a chip, vastly better they really do wonders on diesels.
You can put the induction kit on but it isn't a limiting factor, so won't do anything, might sound a bit faster.
blackbeautyzetec
Aug 29, 2015 02:11 PM
martsmotor
Ford Focus Range
Aug 27, 2015 08:08 PM
Gadget
Aug 26, 2015 01:02 AM
kyle_st200
Ford Focus Diesel
Aug 21, 2015 09:28 PM
jay030787
Aug 17, 2015 06:16 PM
