s2 gearbox rebuild kit question
im looking at doing a gearbox rebuild in my 88 (f) rs turbo s2.
ive seen two kits on ebay a normal one and an uprated late spec gearbox rebuild kit.
does anyone know which kit id need? cheers.
https://passionford.com/forum/showth...=208843&page=9
The big bearing conversion is ok , unless you have the mainshaft break would say if using upto say 180BHP stay std , after that you need a better dif and then the cost of the bearing conversion becomes small in comparison . I have built several of these boxes , they are easy to do , only special tools are the puller for 5th gear and whatever bearings you decide to replace .
please could you send the DIN Norm (specifikation) for the bearings?
thanks
Michael
jonfoc
16
11-09-2018 05:35 PM
