escos engine mounts worn?????
Old Feb 21, 2009 | 09:59 PM
chris wood's Avatar
chris wood
Default escos engine mounts worn?????
hi , i have a problem with my st escos that i suspect is worn engine or gearbox mounts but not 100% sure! here goes, when driving at low speed mostly in 1st and 2nd gear the car seems to rock (kangaroo) back and forth a fair bit if i touch the throttle then come off it again!!! it does not do it if the clutch is disengaged straight after i come off throttle!
any advice would be appreciated. thanks.
Old Feb 21, 2009 | 11:25 PM
The Youth.'s Avatar
The Youth.
the engine mounts on these are prone to failing, carefully jack the car up under the sump don't let it take all the weight just enough to see if the engine lifts before the car, the drivers side is more prone due to it wanting to lift on acceleration,
steve
Old Feb 22, 2009 | 08:53 AM
I would say it's more likely a mapping problem, with a rich spot.
Old Feb 22, 2009 | 07:11 PM
chris wood's Avatar
chris wood
steve
cheers will try that.
Old Feb 22, 2009 | 07:12 PM
chris wood's Avatar
chris wood
not sure abouy that but i am getting it set up soon so will find out!!!!
Old Feb 22, 2009 | 07:13 PM
chris wood's Avatar
chris wood
anymore views on this?
Old Feb 23, 2009 | 06:26 PM
Dangerous Malcolm..'s Avatar
Dangerous Malcolm..
Get a friend to try and set off in first with the handbrake on whilst you watch the engine for movement.
Old Feb 23, 2009 | 06:50 PM
chris wood's Avatar
chris wood
cheers, that sounds a good way off checking, will try that once i get uprated fuel pump fitted. any advice on what mounts to buy and fit if they are worn? not sure if to get uprated mounts or standard ones if ya can still get em? anyone know the price of standard mounts and the difference in drive compared to uprated ones?
Old Feb 24, 2009 | 05:55 AM
You can buy uprated mounts from various sources, in poly, they may transmit some vibes into the car but would not have thought anything to worry about.
I bought a std 2wd mount a while abck and it was about Ł50, so would imagine a ford
4wd mount would be similar.
Old Feb 24, 2009 | 06:08 AM
Neil S's Avatar
Neil S
When my drivers side one failed the gearstick would move noticeably when accelerating as the engine and transmission moved!
Easy to check as the youth describes
Neil.
Old Feb 24, 2009 | 06:28 AM
S1's Avatar
S1
I might be way off here but I remember an article in PF or FF many years ago, it was about a cos that shat out the gearbox. IIRC the coolant temp sensor had gone U/S causing it to kangaroo all the time. The end result was a knackered box due to the constant load on/off.
bigryrs
Mar 28, 2016 09:11 PM
bigryrs
Fiesta RS1800/RS Turbo
14
Jan 21, 2016 09:54 PM
track.focus'd
Aug 12, 2015 05:53 PM
st220kyle
Ford Mondeo Including ST
Aug 6, 2015 09:17 PM
lockie
Jul 31, 2015 10:03 PM
