throttle linkage???
Old Feb 16, 2009 | 08:33 PM
creator's Avatar
creator
Default throttle linkage???
on the throttle linkage where the throttle cable joins the butterfly can you get an uprated spring for them? as mine has gone a little slack and is not shutting the buttlerfly fully so is holding the revs on.???
Old Feb 16, 2009 | 08:35 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
probaly fined that is down to the cable imo try replacing the cable then spraying the lincage in spray grease and work it in by working the throttle (engine off of corse lol)
bet that does the trick
Old Feb 17, 2009 | 12:29 AM
Rax's Avatar
Rax
I would try cleaning the throttle body out first,they can get very dirty and gummed up.It may look clean on the butterfly but on the side you cant see will probably be manky.I have had this before and it wouldn't always shut the throttle off completely.It was more noticeable going down a hill with no throttle and it would pop from the exhaust,it was still chucking fuel in or drawing air.
Old Feb 19, 2009 | 08:33 PM
creator's Avatar
creator
throttle cable it is then cheers guys
Tank Mike
Ford Focus Diesel
Feb 23, 2022 06:09 PM
mk3ste
Oct 17, 2021 10:09 AM
Brickhouse
14
Oct 3, 2015 07:28 PM
mike elsome
Sep 14, 2015 04:08 PM
mike elsome
Ford Range
Sep 9, 2015 05:05 PM
