sierra saff 2wd bleeding brakes
Old Feb 16, 2009 | 10:11 AM
spammi's Avatar
spammi
Default sierra saff 2wd bleeding brakes
Hi i need some info plz
I am changing the front discs and pads on the front and found they are split callipers and is now leaking can anyone tell me how to bleed the brakes
cheers pam
Old Feb 16, 2009 | 11:05 AM
LHD220Turbo's Avatar
LHD220Turbo
start furthest away from the pump; so near side rear, off side rear, near side front and then off side front.
i'm pretty sure that's how i did mine
Old Feb 16, 2009 | 11:09 AM
natehall's Avatar
natehall
on the abs - furthest from the pump in terms of lines is o/s rear, n/s rear, os/front, n/s front on RHD cars
Old Feb 16, 2009 | 02:28 PM
spammi's Avatar
spammi
Cheers peeps nearly sorted, now suffering a slight juddering on the steering when breaking not sure if this is due to just fitting turbo groove discs with pads
Old Feb 16, 2009 | 03:46 PM
LHD220Turbo
are they brand new discs and pads; if so make sure you bed them in properly
FlashRS
13
Aug 31, 2015 06:02 PM
Vincereese
Aug 15, 2015 06:24 PM
155lee
Aug 14, 2015 11:21 AM
Vincereese
Aug 11, 2015 08:44 AM
Old ford
Jul 31, 2015 06:50 AM
