Bleed valves......any good or dangerous?
Old Feb 15, 2009 | 06:43 AM
godzilla's Avatar
godzilla
Default Bleed valves......any good or dangerous?
I was wondering about bleed valves for Turbo'd cars. This seems a cheap and quick was to up the boost on a Turbo'd car......thing is, are they dangerous as in can give to much boost and do engine/turbo damage or is it a cheap and effective way of getting more power without having your car chipped?
Old Feb 15, 2009 | 07:12 AM
barnard's Avatar
barnard
Had a bleed valve on my car for a year and set the boost to what it was before i fitted it.I dont think its dangerous if you do it that way.
Old Feb 15, 2009 | 07:28 AM
GUZZLER's Avatar
GUZZLER
cars will normally have a boost limit to stop any major overboost, ie; split pipe etc, you can only normally raise the boost a bit before you hit the standard boost limiter. a bleed valve is a great bit of kit if treated with respect, there crude but they work, great on cars like RS Turbo's where if you were working on it on a dyno you would have to remove the car from the dyno, jack it up & wait for it to cool down before adjusting the boost on the actuator, with a bleed valve you could just turn the knob a small amount & try another run!
the big problem with them is, people mess with them, crank the boost up but then theres not enough fuel to have a correct mixture, this normally leads to det or high heat then pistons normally start to melt............
Old Feb 15, 2009 | 08:15 AM
Never seen the point myself, when power can be controlled with right foot.
Old Feb 15, 2009 | 08:29 AM
Vic's Avatar
Vic
bleed valve also known as 'dial a rebuild'
Old Feb 16, 2009 | 01:03 AM
Rax's Avatar
Rax
A bit of reading and mixed answers for ya mate https://passionford.com/forum/general-car-related-discussion/281756-erst-chipping-and-use-of-bleed-valves.html
Old Feb 16, 2009 | 07:04 AM
Turbocabbie's Avatar
Turbocabbie
Top Cab !!
That's so true, i've even seen people play with other peoples at shows which is just not right
wheelwizardrefurbs
Sep 5, 2015 10:52 AM
oilman
Trader Parts for Sale.
Sep 4, 2015 09:34 AM
Sep 3, 2015 10:49 AM
turbowag
Sep 3, 2015 08:07 AM
