1.1 HCS White smoke
Old Feb 14, 2009 | 06:28 PM
Rsailor's Avatar
Rsailor
Default 1.1 HCS White smoke
I have a ford fiesta 1.1 HCS push rod engine with single point injection.
I had blue smoke when revved hard so I have replaced the Head gasket and valve stem oil seals.
I have tried swapping map, o2 sensors.
I had a smell of egg so swapped over the o2 sensor.
The car run's rich as you can smell it.
I can either get white smoke or blue smoke by swapping sensors.
I used to have alot of blow back from the oil filler cap but thats sorted since I replaced the valve stem oil seals.
White smoke indicates water but I don't know where its coming from, if its leaking at all.
Has anyone had the same problem???
Old Feb 14, 2009 | 07:12 PM
Is it using water ?, as this time of year they all smoke terribly when cold.
Old Feb 14, 2009 | 07:40 PM
Rsailor's Avatar
Rsailor
Not sure at the moment. I've just put a secondhand engine in it.
Its got no t and t so a road test would be risky. I need to get it through an mot for my wife to use.
I reckon the map sensor, cat or o2 sensor is duff that is causing the over fueling.
White smoke - Cracked head or block, Could be the inlet manifold not sure.
Tomorrow I'm going to break out the multimeter and start checking everything.
Old Feb 14, 2009 | 07:44 PM
stembo21's Avatar
stembo21
i have a 1.1 fiesta hcs let me know if you need out as am brakeing it
Old Feb 14, 2009 | 09:53 PM
Rsailor's Avatar
Rsailor
OK, Cheers mate. I have quite alot of spares but If I need some thing I'll give you a shout.
Old Feb 15, 2009 | 08:18 AM
I would put a new CTS in as a matter of course, to start with.
This is the main factor governing the co, so needs to be right.
I did a festa last year a r reg one(1.25 zetec se) that was one of the damaged ones from Tesco petrol, and had been like it a few years, only a new lambda on that DESPITE it showing correct on gagues/metres, was switching way too slow, wasn't able to check speed with what I had at time, so took a chance.
bobsworth
77
Mar 24, 2016 09:30 PM
Steve Escos
Oct 1, 2015 06:57 AM
SMILER258
Sep 28, 2015 09:04 AM
mondeomark
Sep 28, 2015 06:28 AM
