Fiesta rs turbo act sensor
Old Feb 14, 2009 | 02:12 PM
esh's Avatar
esh
Default Fiesta rs turbo act sensor
Does anyone here know the thread type & size of these air charge temp sensors?
I'm sure they're NPT thread but just want to make sure!
I'm about to buy some weld-on boss's for my custom plenum and as such need to know the correct thread type.
Thanks for any help,
Jim.
Old Feb 14, 2009 | 05:21 PM
JonathanJ's Avatar
JonathanJ
will go out in the am and see what it is , cannot do it now as taking the wife for a meal , have to keep her sweet you know , will repost in am with the required info
Old Feb 14, 2009 | 05:27 PM
esh's Avatar
esh
Cheers buddy - Mrs Esh & I are just off out for a Valentines do so yeah I'll check again tomorrow, thanks.
I know the Esc Cos item is M14 x1.5 apparently and the FRST item has a thread adaptor to make it the same as the '2i one...
Old Feb 15, 2009 | 09:58 AM
JonathanJ's Avatar
JonathanJ
Right been out to garage and got my spare convertor , the manifold ( male ) end is 3/8th npt , ie 18 threads per inch (1.4 mm pitch) with a major diameter of just over 17 mm , the female end is M12 X 1.5 mm , ie the same size as wheel stud / nut threads if you want to check yourself .
Hope this helps .
Old Feb 15, 2009 | 10:40 AM
esh's Avatar
esh
Hope this helps .
Cheers mate, think I just replied to you on FT.com too!
paceo
Feb 3, 2016 10:31 AM
carlo
24
Oct 5, 2015 08:20 PM
Ben26
Aug 27, 2015 08:56 PM
paceo
Aug 27, 2015 12:45 PM
knight19770
Aug 4, 2015 12:36 PM
