xr4i diff
Old Nov 26, 2004 | 09:05 PM
ErikH's Avatar
ErikH
Default xr4i diff
Dear Sir!
Anyone know if the xr4i has a 7,5" diff or a 7" diff unit, and if anyone know the ratio on cwp.
Regards
Erik
Old Nov 28, 2004 | 05:56 PM
nicksaph's Avatar
nicksaph
hello mate the ratio is 3.62:1 same as the 4x4 and i belive it is a 7.5", it is the 4x4 that uses the 7" diff
Old Dec 1, 2004 | 03:34 PM
extra14's Avatar
extra14
no it must be 7" on the xr4i as there was never a 3.62 7.5" diff.
Thanks
Darren
Old Dec 1, 2004 | 08:54 PM
BOBXR4X4's Avatar
BOBXR4X4
second that smallest diff on 4i, 4b4 has bigger diff & cossi bigger still me thinks
Old Dec 1, 2004 | 09:22 PM
extra14's Avatar
extra14
i think the xr 4x4 and xr 4i are the same diff (7"), the granadas and cosies use the 7.5"
difs
Old Dec 3, 2004 | 01:21 PM
Rob's Avatar
Rob
The XR4x4 V6 uses a 7" 3.62 and the DOHC XR4x4 uses a 7" 3.92 Viscous LSD's. The XR4i V6 uses a 7" 3.62 non LSD diff however uses the push in style driveshafts so isnt a straight swap. Ideally the easiest way to convert a XR4i to LSD with the same final drive is to use a whole rear beam from a mk1 XR4x4, alternatively a mk1 Cossie as the final drive is near dammit the same. and you get rear disc's as a bonus
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Iain Mac
Sep 30, 2015 09:39 PM
mark r
Sep 29, 2015 07:27 PM
cossie brad
Sep 29, 2015 02:38 PM
DavidK
Sep 27, 2015 02:55 PM
